Old 01-04-2009, 03:33 AM
Bryan Wood's Avatar
Bryan Wood Bryan Wood is offline
Default Notam, Pirep, or What?
Can a pilot Notam a field? Tonight when the runway lights failed at my home field I tried to Notam the airport and was told that only the airport manager can do this. (It was 1a.m. local and the airport manager was at home asleep) For some reason I thought it was SOP for a pilot to Notam the field after events such as a Gear Up incident, or similar. Because of this assumption I tried to let the folks know at WX Brief about the dark runway. They blew me off. With a change in strategy I told the lady to consider it a Pirep and she said she noted it. It has been a couple of hours and it still doesn't show up on Weathermeister. So what's the deal? What do you do when the airport has a problem or potential hazard?
Bryan 9A Sold
Beech S35, and daydreams of a Super 8 or a Rocket starting to take over my brain.
Old 01-04-2009, 08:08 AM
FlyinFife FlyinFife is offline
Default Good Question
You pose a good question. To the best of my knowledge, only "official" airport people can issue NOTAMs for a particular airport. I think you are on the right track about issuing a PIREP. If you felt like Flokheed-Schmarten Flea Circus is blowing you off, try getting ahold of the nearest ATC facility; either a Tower, TRACON, or ARTCC. Obviously this is easier if you are in flight, but might still be possible on the ground depending on where you are. That's just my $0.03.
James
Phase: Strategic Planning (i.e. daydreaming)
Model: RV-8
Tail Number: Unassigned
Engine: Unassigned
Propeller: Unassigned
Avionics: Unassigned
Paint Sceme: Unassigned
"You asked me what my dream panel is; the fact that it won't fit is completely irrelevant."
Old 01-04-2009, 08:33 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
I had to work to get authorization to issue NOTAMs at 00V. Best thing to do now is contact the airport manager and have him call in the NOTAM and fix the problem.
