Old 01-03-2009, 02:03 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default cowl-starter ring alignment
Can anyone tell me how far (fwd) to cut the cowl inlet flange. Should it be forward of the starter ring or does it matter? I was tentatively going to trim the cowl approximately where the blue line is, but perhaps I should just leave it? I assume the front baffle bulkheads will almost butt up to the aft edge of the cowl flange here, but does it matter what is adjacent to the starter ring, cowl or baffle? (I currently have about 1/2" between cowl and starter ring.)
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 01-03-2009, 03:05 PM
174Bob&Nancy 174Bob&Nancy is offline
Smile
You should not have to cut anything off the cowl inlets they will work great as is,Bob.
Old 01-03-2009, 03:09 PM
pierre smith's Avatar
Default Bob's correct......
.....but you'll need to trim the lower baffle inlet to about 3/8"-1/2" back of the fiberglass intake......that's so you can fold the rubber up as you raise the cowl to install/remove it.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-03-2009, 04:20 PM
Thanks guys. Makes sense.
Steve M.
Ellensburg WA
