Electrical question
I'm wiring up the elevator trim servo. I ordered the extra trim cable, and it reaches the panel. However, I want to make a run from the panel to the trim switch in the joystick. I have a lot of 22 ga wire left over, and would like to use it instead of ordering another length of cable, or 24 ga wire. Could I use the heavier wire with no ill effects?
The stick switches are all pre-wired with 22 ga
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
