01-01-2009, 01:35 PM
mate-n-lok
My Vans Lighting System 6 came with a bunch of "Mate-N-Lok" connectors to be assembled (housings, sockets, pins). Do these require a special type of crimper to attach to the wire?
Does anybody know where i can find instructions on installing these?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
01-01-2009, 02:14 PM
TerminalTown.com sells the crimp tool, the pins and the connectors. If you already have the tool the only other thing you may need is the pin insertion/extraction tool.
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
 RV-9A Firewall Forward
[Engine purchased]
01-01-2009, 04:38 PM
Alternative to this type connector?
I hate this type of connector. I've used them in a few places but I find these very difficult to work with.
Just today I was making one of my last wiring connections, the PTT on the co-pilot stick. I started doing it with a small mate-n-lock connector because it's are small enough to fit in the stick. After messing with it for a while, I decided to try to find a different type of connector. Any suggestions for an alternative to this type of connector?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Reason: grammer
01-01-2009, 07:10 PM
PTT alternative
I just used standard insulated PIDG insulated spade connectors for the PTT connections:
I did the same thing on the passenger side but just before final inspection I pulled that wiring out of the stick and mounted the passenger side PTT in the panel on that side to make it less of a hassle installing/removing the passenger side stick (given my wife's and my son's preferences, I expect to be removing/installing relatively often once out of Phase I).
I only used the mate-n-lock style connectors in a few places, primarily on lines with three or more conductors.
other pictures at:
http://rv6aproject.ckhand.com/panelA...ctricalPg7.htm
01-01-2009, 08:13 PM
I LOVE the Mate-n-Lock connectors. I used them exclusively in my RV-6. After 11.25 years flying and more than 2,188 flying hours, they work great, have great reliability, and are easy to service. They are the BEST VALUE out there. IF there is something better is a LOT more money and more difficult to work with.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
01-01-2009, 08:46 PM
Have you considered Deutsch connectors? They have a range of AutoSport (WRC, F1, etc) connectors and variants. Not even close to being the cheapest solution, but compact, light and reliable. They have GA and upwards products too... I've never tried to source those though. There's plenty of alternatives more comparable to Mate-N-Lok, like Metri-Pack and Weather-Pack, so have a browse in some automotive wiring catalogs... eg Waytek (although I see Aircraft Spruce has " Seal-All" that look just like Weather-Pack).
01-01-2009, 09:26 PM
Whether you like 'em or not, it probably won't be the last open barreled type pin you crimp in your plane, so you should invest in an open barreled pin crimper. I think ours is about $30, and is good for the molex pins (we sell the exact same one B&C does), narco/king/icom square pins, small Garmin ground pins, etc.. Get one and you'll be glad later on down the road.
Stein
01-02-2009, 07:37 AM
Stein, I already have 2 different open barrel crimpers but I may just go ahead buy yours to see if it helps. I have one that looks a lot like your SAT-018 and I also have an open barrel die set that goes in my Paladin ratching crimper.
The problem I have is that either the crimp doesn't lock on the wire or the body of the connector gets deformed and won't go into the Molex connector.
I also have a heck of a time getting the pins out of these connectors. I've already destroyed one SAT-033 (blue) insertion/removal tool
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
01-02-2009, 08:40 AM
Thanks Guys!
Yesterday I sent an email to SteinAir ordering their Master Kit, and i see it includes an Open Barrel Crimper... sounds like that should do the trick!
Also ordered SteinAir's large black anodized vents... thanks to all those who gave their recommendations for these.
Phil
RV9A (SB)
Ottawa, Canada
