Old 01-01-2009, 08:09 AM
prkaye prkaye is offline
Default coarse thread bolt
The bolts that hold my oil sump on the engine are similar to AN4, but they appear to have a coarser thread. I had to remove one to attach my ground strap. Anybody know what torque value I should use for this type of bolt?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 01-01-2009, 08:33 AM
az_gila's Avatar
az_gila az_gila is offline
Smile From the ECI Hardware Manual...
...it is a standard 96 in-lbs for a 1/4 - 20 bolt.
Note that engine torque numbers specify clean 50 weight oil on the threads and surface under the nut and bolt.
Happy New Year....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
