I agree
I agree with Kirk, the spacer is what is causing the fit up issue. The temperature difference has no effect on fit up because the rest of the fuselage is at the same temperature as the top skin. In otherwords, everything that is made out of the same material shinks and expands at the same rate.
Eric Wolf
RV-8A Flying since May 2009, 300+ hours
Mattituck IOF-360, WW 200RV Prop
N184EW
Past President, EAA838 Racine, WI
