12-31-2008, 06:40 AM
Quick Disconnect on Shielded Wire
In my -8 there is one shielded wire with which I would like to have quick disconnect capability. Is this OK, and if so, what's the best method? D-Subs? Deans connector? Something else? Don't do it  ? Should the shield wire go across the connector or is it OK to have a short piece of a shielded wire unshielded (in other words, the short piece of the connector itself remains unshielded)?
Jim Shannon
RV-8 N52VV
Charlottesville, VA
12-31-2008, 07:12 AM
Jim,
You don't say what the application is, but typically it is acceptable to have a short portion of the wire unshielded inside the connector. If you use something like a d-sub connector with a metal backshell, it is still somewhat shielded from outside sources, although not from other wires within the connector.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
12-31-2008, 03:25 PM
Jim,
What's the application?
If it will be repeatedly plugged/unplugged as part of normal operation & it's a 'non-critical' item, there are many choices at your local Radio Shack or local equivalent. (Higher quality versions of the same connectors are available from a good audio supply house. Switchcraft is a good brand.)
The lightest weight ones would probably be the mini-phone plug connectors, similar to the headset connector on an Ipod except mono instead of stereo. You can get the plug and a mating in-line jack. If they don't have the mono version, just buy the stereo & ignore the 'ring' terminals in the connectors. The only real downside to them is lack of locking feature, but if you are hooking up a portable device the lack of lock can be an advantage (snag the wire & it unplugs instead of breaking the wire).
If you need a lock, check out the 'XLR' type connectors used for balanced mic lines in pro audio equipment. They are a *lot* heavier (ounces instead of grams), but do have the lock feature & will carry substantial current loads if you are powering something with this line. They have 3 terminals, but the metal shell can be used as a 4th terminal. All combinations of in-line or panel mount, Male or Female are available.
Charlie
12-31-2008, 08:38 PM
This particular application is for a four wire shielded cable exiting the fuselage and heading out to the right wingtip. The cable is for a Dynon remote compass. I'd like the quick disconnect capability for ease of wiring the aircraft right now, and later when/if a wing is removed all you have to do is uncouple the connector to remove the wing. Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
01-01-2009, 06:50 AM
The shielding on the Dynon EDC is not all that critical. You can get by with pretty much any connector.
01-01-2009, 06:24 PM
Another one that would be handy to have a disconnect on is the serial altitude encoder wire going to the GTX327 Transponder from the Dynon D100. Would this one be OK to have the disconnect on?
Jim Shannon
RV-8 N52VV
Charlottesville, VA
01-01-2009, 09:33 PM
It would probably be ok, but I fail to see what the benefit would be. Extra connectors add extra complexity, and reduce reliability when they are placed in areas where they are not needed.
Also, again Mel is correct. On the Dynon remote compass line it's not that terribly picky....
Stein
01-01-2009, 10:05 PM
The only advantage is when removing the panel from the airplane. A quick disconnect on that line, plus other wire terminations at terminal blocks, allows the whole panel to be easily removed. It's not that big a deal, and if it's better I'll leave the disconnect off.
Jim
01-02-2009, 12:09 AM
Hi Jim,
I understand your reasoning, but I'd discourage connectors for that application or future reason. I usually try to push everyone to build their planes (in their entirety - including systems, structure, etc..) for the 99th percentile of use/maintenance....not the 1 percentile of maybes. How many times do you see yourself removing the panel for anything other than upgrades, etc..? There is an entire slew of other items that make removing the panel a not so simple affair so I'd just say don't worry about it. It's one wire out of many things. Even the "plug & play" panels you see come out of professional shops are NEVER that simple. There is a LOT of other things that your panel ends up having connected to it.
My 2 cents!
Stein
01-02-2009, 06:10 AM
I've had this question myself but not in the context of removing a panel. I've wondered about wing root disconnects and what happens to the strobe drain wire at the connection. What I presume the answer is here is that it should be treated as any other wire.
The reason it's an issue for me is I'd like to get the wings on under the assumption I can fly it off the field I'm at BUT the field I'm at is in transition. The FAA and DARs are trying to "discourage" first flights but it's not entirely set in stone yet and there's the possibility I could fly it off the field and land it somewhere else and there's the possibility that I'll have to dismantle the thing and truck it to that "somewhere else."
At the same time I'd like to wire up the landing ligts and Tru Trak (well, actually, I would have to cut these wires since I bought Stein's harness) and strobe navs under the assumption that I won't have to deconstruct the darned thing.
