Originally Posted by MJarreau
In the industrial work we do, we make every attempt to wire top-down, left-to-right. That is, power on the top comes out on the bottom, power on the left comes out on the right.
I agree with Bob Nuckolls' write up in Matronics.
...way might be a bit safer... with the power IN on the bottom side.
Gravity always ensures that the tools you drop fall downwards...
...and a input side buss bar is always hot when the master is on.
If the screwdriver falls on the OUTPUT side of the breaker, all it will do is trip the breaker.
A minor detail, but given the choice, I think it is slightly safer, and just as easy to do. Bob N's article does not specify the "wire top-down" you mention.
