Old 12-30-2008, 10:51 AM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
Default RV-8 Oil Cooler
As per the instructions I have mounted the Van's EA II oil cooler on the suggested baffle as high as possible. To enable the factory supplied mount to work I have ended up with what I feel is fairly minimal clearance between the oil cooler and the cowling. Can anyone give me an idea of how much clearance I need in that area. I have between approximately 1/4" and 3/8" gap between the cooler and cowl.
I understand all of the comments about the engine "shaking like a wet dog".
In the real world, what works for clearance? Any comments and or photos would be greatly appreciated.
Happy New Year to all!
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
Old 12-30-2008, 11:51 AM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
Default 1/4" too close
Jeff - with only 1/4" clearance you're almost surely going to see the cooler knocking against the cowl. 3/8" also seems too close to me. I'd suggest 1/2" as a practical minimum.
I had an RV4 with the cooler mounted behind #3 like yours. It had 1/2" clearance and there was evidence of intermittent contact.
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
Old 12-30-2008, 12:00 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by jeffmoreau View Post
As per the instructions I have mounted the Van's EA II oil cooler on the suggested baffle as high as possible......
In the real world, what works for clearance. Any comments and or photos would be greatly appreciated.....
Jeff,
Been there, done that. Because the curvature of the RV-8 cowl is considerably different than exists on the side by side models, I ended up scrapping key pieces of baffling when I attempted to mount the oil cooler in about the same location as I did on my -6A. Those baffle parts were about the only parts I had to scrap and replace during the entire build process. Here is a link that describes the problem and my post #19 includes photos that graphically illustrate the problem and what I had to do to make the oil cooler fit the baffle while maintaining adequate cowl clearance. Good luck.
http://www.vansairforce.com/communit...ghlight=baffle
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
Old 12-30-2008, 09:40 PM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
Jeff,
If the cooler is already mounted I'd leave it alone until you're flying, and then check for rubbing. Easy enough to fix later.
I have my cooler mounted similarly close to the cowl and there's no evidence of contact. The higher you can mount it, the better cooling you'll get.
Alan Carroll
RV-8 N12AC
