Hello Dennis,
First, it would help you and others if you put your location information in your profile here on VAF - you'd probably have responses from six builders within fifty miles if they knew you were in the neighborhood!
But....wiring these boxes isn't hard. Take the individual wiring diagrams and lay them out on the table. Then look for the audio, mic, and PTT lines from each radio and write down the pins in a table. Find the audio panel diagram and write down the pin numbers for the same lines it is expecting from Comm 1 and 2. Eventually, the whole thing will come into focus. Using a separate intercom DOES make it a little more difficult, but that is where someone close to you could help.
Good luck!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
