Old 12-22-2008, 10:51 AM
STHorstman STHorstman is offline
Default Mooring eye placment for tie-downs
We will soon be pouring concrete for the driveway leading to my hangar. I was going to get 3 mooring eyes placed in the drive outside the hangar for times when either a guest or I need to park outside (my wife's already threatening to kick the -10 out to host scrapbook parties).
Does anyone know what the standard distances (if there are standards) between the thre eyes for a small plane?
Also, I found mooring eyes at Pacific Marine & Industrial (http://www.pacificmarine.net/airtiedown.htm) does anyone know of a second manufacturer or vendor?
Thanks in advance!
Steve H.
RV-10, Empennage
Old 12-22-2008, 03:49 PM
az_gila's Avatar
az_gila az_gila is offline
Smile As always....
Thanks in advance!
...the FAA has a standard....
In this case it's in the AC on Airport Design... and the relevant page is here...
http://www.seasideairport.org/faa_tiedowns.gif
The 45 ft spacing is good for singles and small twins. It could be reduced to 40 ft for Cessna 182 size and smaller planes.
The size of the yellow painted "T" is nicely dimensioned above.... I think these are the numbers you arr looking for.
Some of my airpark neighbors put bent pieces of rebar into the concrete when it was poured, with a cardboard tube to make the recessed hole.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-24-2008, 08:12 AM
Default Thanks
That was exactly what I needed to know. Thank you!
Steve H.
RV-10, Empennage
Old 12-24-2008, 09:06 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Re-bar, or most any form of steel rod of adequate size. Re-bar rusts, so if you are in a wet place---------
Bend into a "U" shape, flare the tips out a bit, for additional holding strength.
Get some cheap stainless salad bowls, couple holes in the bottom for the rods, set the whole mess into the wet concrete.
I would suggest digging out a little deeper in the area of the tie downs, maybe a foot square and eight inched deep, just to give the slab more local strength. Also gives the legs of the hold down somewhere to go.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
