Originally Posted by grover
but in this case, where maintaintability will be dramatically improved, I'd opt for longer. had similar situation with my dynon, and it suffers no ill effects of longer than standard shield grounds.
...a 10 inch "shield ground connection" is actually a recieving antenna....
Since we are dealing with shields to negate the effects of stray RF, the extrapolation from one aircraft to another is not really valid. Unless all of the avionics are identical, and installed with identical harnesses, there is no real correlation.
Why not get a small push on tab connector, and connect the shield wire to a tab mounted on a screw on the back of the D100 unit itself? ...perhaps to one of the D-Sub mounting screws. It does not really have to go to airframe ground directly in this case.
I don't have the specification handy for the shield pigtail length, but it is in the order of 1.5 inches maximum for the frequencies we usually deal in.
