ACRO?
It really doesn't matter with the master. This is more critical on the starter solenoid than the master. The master will be engaged during flight anyway.
For the starter solenoid it depends on how much acro you intend to do. During normal 1-2 Gs, it doesn't matter much.
If you are going to do a lot of aerobatics, then the G forces can eventually weaken the spring.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
