12-17-2008, 06:39 PM
Rivet drill bit
I have to wonder why we use a # 40 bit for an AN426 3/16" rivet when a closer tolerance bit seems more appropriate?
12-17-2008, 06:57 PM
I use #41's.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
12-17-2008, 07:00 PM
Easy answer from AC43.13.
The rivet swells to fill the hole, and the cross-sectional area of the rivet determines its strength.
If you drill a smaller hole, the rivet won't be as strong.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
12-17-2008, 07:02 PM
#41
When we went to the Alexanders Technical RV Builders school in Griffen, GA they taught us to use #41 bits and reamers in place of #40's for that exact reason. We are currently on the finish kit and have used #41's all the way through... I don't think it makes much difference, but we did do the math and it does make sense to use 41's
Paul & Beth Duff
N2724G - RV9A - 1000+ Hours
Vans # 91642
FLYING 10.15.2010
BLOG: http://2flyamerica.com/
12-17-2008, 08:03 PM
So what size dimple die are you using? A custom made #41 die?
After you dimple with a #40 dimple die the hole is going to be just as wide as if you had just drilled it with a #40 drill in the first place. Worse, however, is that now you've stretched the hole to #40 with the dimple die rather than drilled it. That's how cracks get started. Maybe it's such a small difference that there will be no ill-effects, but the logic of drilling with one size and then dimpling with a larger size kind of escapes me.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
12-17-2008, 08:26 PM
This falls into the, "thousands of airplanes have been built with..." category.
In this case, thousands of planes are flying that were drilled with #40 drills and no reamer so why change what works?
Besides, that means running a tool through every hole a second time, which takes even more time. Drill w/ a #40, deburr, dimple, and move on.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
12-17-2008, 08:28 PM
KISS!
I gotta go along with Bill here. No need to over complicate things.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
12-17-2008, 08:39 PM
#41 bits/reamers
A #41 bit/reamer is .0960". My 3/32 male dimple die measures .0930 so there is still clearance and I don't think I am stretching anything because of a #41 reamer and a 3/32 dimple die. A check of a few holes with a magnifying glass shows no difference of dimpled holes reamed with #40 vs #41.
(added) I only use the #41 reamer for match drilling pre-punched holes so it's not an extra step.
Don
VAF #1100, EAA864
-6A bought flying
Reason: added statement
12-17-2008, 08:53 PM
Rivet drill bit
I want to thank everyone for their input. I spent 400 hours with another builder building a 6A airframe in 2000 and the rivets never seemed as loose as they are now so I did the math and started thinking. I am currently building an 8A by myself and I am thinking too much for my own good. Vern?s answer hits the spot for me and I also ordered the book titled Aircraft Inspection Repair and Alteration
Again thanks
Wendell
RV-8A
