10-21-2005, 06:15 AM
Fraction Finder Utility
For those out there like me that may be a little math-challenged...
Have you ever seen some random decimal value in the project and wondered if there was a fractional equivalent without having to resort to trial and error with a calculator or a chart? Well, me too. I wrote this little utility that allows you to enter any decimal value and it will give you exact as well as approximate fractions. I thought some of you may find it useful.
Fraction Finder
10-21-2005, 08:01 AM
hmmm.... "math challenged" and writes code to do this? I think you and I have a little different definition of challenged !!
Looks cool! Thanks - now I just have to get a laptop and wireless in the shop!
Thomas
-8 wings
10-21-2005, 08:45 AM
Having to resort to such a crutch tells us that our way (U.S.A.) of measuring is right out of the stone-age. Once you have had a taste of the metric system, you will never want to go back to the Imperial system. I have one of the neat rulers from Avery which has the standard Imperial markings on one side, then a faux metric (inches which have been divided into 100ths on the other side) Guess which side I use? Didn't President Carter attempt to launch the US on the path of the metric system?
Rant over
Tinman (All 68KG of me)
10-21-2005, 09:00 AM
Tinman,
Funny you bring this up, we were just talking abou this the other day. I just hate working in the Imperial system, Metric is so much easier.
Last night a friend came by so I cold help install a hitch on his new Dodge pickup and wouldn't you know it, they aren't metric. I had to dig out my old sockets and wrenchs, the big ones.
I now have two complete set of tools, one for the plane and one for almost everything else.
My $.02 worth from all 98KG of me.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Rant over
OK,
I have 3/16 of a millimeter. What is that in decimal?
Looks like the same issue to me.
-mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
10-21-2005, 09:04 AM
I agree. Metric is almost always a better system of measurement.
I went to Sears yesterday to buy a 7.9mm drill bit to use on my gear legs (the plans call for 0.311 and a 7.9mm bit is 0.311023622). But nope...I can't find a metric drill bit anywhere....Sears...Home Depot, Lowes, Ace Hardware -- nobody has 'em.
10-21-2005, 09:39 AM
Jamie,
Try Wholesale Tools. They have 7.9mm Drill bits.
Bill R.
SC86 - Easley, SC
10-21-2005, 10:12 AM
Originally Posted by N941WR
Nevermind. I just realized that Avery has a reamer that's the correct size for the gear legs. It is listed as "5/16? UNDER SIZE CHUCKING REAMERS -- HIGH SPEED STEEL", SKU# 15358.
10-24-2005, 05:13 AM
<snip>
OK,
<end snip>
In case you are not kidding us, I will take the bait and answer...
The metric system does not use fractions. It is a decimal system. You should never have 3/16th of a mm. If you do, you have picked up a virus along the way while trying to do the math of conversion :-)
Tinman
10-24-2005, 07:06 AM
<snip>
OK,
<end snip>
Tinman
Apparently I was a little too brief with my answer. Converting fractions to decimals (or vice versa) is a unit-independent operation. It has nothing to do with Metric versus US. That argument (M vs US) is separate.
If I have a 1/4 liter of something, I can convert it to thousandths of a liter and call it 250 ml.
If I have a 1/4 inch of something, I can convert it to thousandths of an inch and call it 250 thousandths of an inch or 250 milli-inches.
Same process both ways with the same numerical result.
I stick with Same-O-same-O
-Mike
Michael L Wilson
VAF# 148
Payson, AZ
