  #11
Old 12-17-2008, 06:49 AM
N395V's Avatar
N395V N395V is offline
If you watch trade a plane, controller, VAF classifieds, and e bay the TWs and nosewheels seem to come and go at the same rate. I doubt one is more saleable than the other.
More important than where the wheel is is how well built the plane is, The aesthetics of the paint and interior and how it is equipped and of course the price.
Milt Concannon
Steve Steve is offline
Default what?
Airshows only??
So Van doesn't plan on flying the 10 (nose wheel) he built with his brother?
Steve
Old 12-17-2008, 07:36 AM
Dave Cole's Avatar
Dave Cole Dave Cole is offline
Default Show me the nosewheel
Steve, I think the point is that Van flies nose wheel airplanes to airshows to show them, and nose wheel airplanes are what most people want to see.
Personally, I'm a tailwheel guy.
Dave Cole RV-7 N97DC reserved
dave.cole@cox.net
Started SB April 2004
Hope to fly in 2011
Old 12-17-2008, 07:47 AM
RV8iator's Avatar
RV8iator RV8iator is offline
Default Mannon, can I borrow your NOMEX suit
Originally Posted by Dave Cole View Post
Steve, I think the point is that Van flies nose wheel airplanes to airshows to show them, and nose wheel airplanes is what most people want to see.
Most people who don't have the confidence in their flying abilities..
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 12-17-2008, 08:19 AM
JonJay's Avatar
JonJay JonJay is offline
Default Enjoy the build or keep it for yourself...
Originally Posted by Steve Barnes View Post
I recently purchased an RV6 kit from a friend at a reasonable enough price to build and sell.
I did the math when I was looking for a project. Even if the kit was free by the time you add in the Finish Kit, FF parts, engine, prop, avionics/instruments, wiring, paint (or not), 1000 hours to complete, you still end up with an airplane worth about what you put into it. You might be able to make a few bucks if you go cheap, "used" parts on pretty much everything, and are a really efficient builder.
So, enjoy building it because that is what you will get out of it. Of course, that experience is priceless in my opinion.
I would keep the kit as is. It will be sellable either way and you will have a lot more work to finish it than you might think so switching to nose wheel would be expensive and time consuming.
As with all things right now, prices are pretty depressed. You might do better if you can hold onto it for a while.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 12-17-2008, 08:25 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I'm getting tired of this................and will change my previous answer....to convert to a nose gear..
Other than that, it's again being practical. The "other" thread relating tailwheel accidents due to lack of visibility is a good example.
I personally know two pilots who ended up cramming a Pitts S2B into a aircraft towing tractor because the tractor ran out of gas at the wrong time, with a blinding setting sun behind it. This aided in my decision to finally go with the nosewheel, where visability is improved.
Now, other than that, RV8's must be taildraggers for WWII markings. It's the only reason I can thing of..
Apparently RV taildraggers are not that hard to fly, so the RV TD pilots aren't really macho enough! They don't behave badly enough, and are easier to see over the nose..
And lastly, REAL taildraggers are meant for bush type flying along with tundra tires. This is where taildraggers are truely practical. If you don't dare take your RV into those type of conditions, then get a REAL taildragger!...
L.Adamson --- RV6A
Old 12-17-2008, 08:35 AM
Mel's Avatar
Mel Mel is offline
Default I feel better now!
L.Adamson --- RV6A
You really had me concerned. From your previous post, I thought someone had stolen you identity. But you forgot to tell him that it will never sell unless it has a constant speed prop.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-17-2008, 08:46 AM
L.Adamson's Avatar
Mel,
It must have a constant speed prop, electric elevator trim on the stick, sliding canopy, optional aileron trim (I really like mine, see below).........to sell well! And throw in a 696 on the panel too!
P.S. --- I'm more than thrilled with my little electric trim tab on the aileron ---- as Van's did in the old days, but still available. Being set in my old ways, I've never liked bias springs. But FWIW, the aileron trim really does make a difference when flying alone, or with two in a side by side.
Anyone who says different.........doesn't like a well trimmed airplane!
L.Adamson --- RV6A/ 0360/ Hartzell CS/ Garmin 696/ sliding canopy
edit: I knew I missed something.............electric flaps. No more reaching between two people for a flap handle. Just a finger on the convenient switch, while the rest of the hand is on the throttle.
Old 12-17-2008, 04:32 PM
mkraus01 mkraus01 is offline
Talking
I recently purchased an RV6 kit from a friend at a reasonable enough price to build and sell. The fuselage is nearly done and the wings are nearly done. It was built as a tail dragger. As far as saleability is concerned, would it be better to modify as an A, or just complete as is? Number two idea is to purchase a 7 vert. stab. so it looks more modern. I have noticed that in recent years there is a dwindeling supply of new tail wheel pilots, so thats the reason I'm considering changing to an A.
Good question. While you are at it, why don't you ask what is the best primer to use too!!
Old 12-17-2008, 08:56 PM
gasman gasman is offline
Originally Posted by gasman View Post
Leave the stock vert. stab. It is a classic, and fits with the the rest of the airframe.
Van will only fly nose wheel aircraft to air shows.......... Ask him why?.........
HERE IS A HINT..............
I personally know two pilots who ended up cramming a Pitts S2B into a aircraft towing tractor because the tractor ran out of gas at the wrong time, with a blinding setting sun behind it. This aided in my decision to finally go with the nosewheel, where visability is improved. L.Adamson --- RV6A
