Old 12-16-2008, 07:40 PM
Dave Watson Dave Watson is offline
Default Does this Elevator Bend Look OK?
Bent the elevator trailing edges today and I wanted to see if you think this is OK or do I need to bend it further? There's just a very slight gap between the skin and the straight edge in the last inch.
Thanks for your input.
Dave Watson
RV-9
Locust Grove, GA (Mallards Landing)
Old 12-16-2008, 08:15 PM
fstringham7a fstringham7a is offline
Default RE:More in IMUO
Dave
Mine looked the same until I really put the bend to it. I had a 1/8 dowel taped in the radius which really helped keep it in place and maintain a good radius. I also taped the bottom skin edges to the home made bending brake so it would not move out from the point of the bend.
Frank @ 1L8 ...RV7A... painting.....VS/Rudder
Old 12-16-2008, 08:41 PM
Wicked Stick's Avatar
Wicked Stick Wicked Stick is offline
That looks pretty darn good to me.
Dave "WS" Rogers
RV-8 N173DR
Old 12-17-2008, 07:47 AM
Thanks. I have to fight the urge to keep tweaking something because I have a tendency to keep trying to improve something to the point where it starts going downhill. I need a team of Van's engineers to look over my shoulder and tell me when to stop.
Dave Watson
RV-9
Old 12-17-2008, 08:12 AM
Mel's Avatar
Mel Mel is offline
Dave, What you show in the picture looks fine. What I would look at is between the stiffeners. This is where many have a "bulge". If what you show is consistent from end to end, you're in good shape.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-17-2008, 08:18 AM
Thanks Mel,
I didn't even think to check laterally. I've taken everything apart for de-burring and dimpling but will check that when I re-assemble.
I appreciate the responses and the great feedback this message board provides!
Dave Watson
RV-9
Old 12-17-2008, 08:59 AM
TerryWighs TerryWighs is offline
Dave...
I bought a "Radius-Gauge set" from www.yardstore.com for about $25.00 that has been very helpful in the building process...when working out brake work for elevators,ailerons, etc....Check it out.
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
