Old 12-16-2008, 06:50 PM
Jeff R's Avatar
Jeff R Jeff R is offline
Default Brakes hard as a rock after bleeding
I semi-successfully bled my brakes finally, using Mobil 1 ATF. But, I have issues. The main issue is that the brakes feel extremely hard. It is like the system is locked up. No, the parking brake is not set, but the pedals will only move a little bit. The reserviour is vented so I don't understand why all the brakes, both left and right and passenger side and pilot side, are so firm.
I am thinking that the brake pistons are pressurized and not relaxing. In bleeding the left side, in particular, I had a lot of trouble. I had removed the brake from the wheel and tried bleeing it that way, and the piston came out and later, even after I removed the bleeding plug, it would not retract until I wedged a screwdriver and forced it. It seemed to me that the brake was locked up irrespective of the bleeder valve being off. How could that be? I put it back on the wheel and got fluid to flow upwards and thought all was well, but now both brakes are hard as a rock. There are some air bubbles in the line between the two master cylinders on the pedals, but they only move an inch or so when I press down hard on the brakes. The pistons appear to be firmly up against the brake pads.
Any ideas?
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 12-16-2008, 06:52 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Are the pushrods in the master cylinders all the way out???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-16-2008, 07:06 PM
Sam Buchanan's Avatar
been here awhile
Any ideas?
Sounds like you have successfully bled your brakes.
There will be very little pedal movement. Jack up the wheels and make sure they rotate more or less freely without the brakes applied. If the wheels are free until you apply the brakes.......well......that is what brakes are supposed to do....
The pistons will maintain very light contact with the rotors. This is normal. It would be nice if the bubble between the cylinders could be bled out, but if you have firm brakes that work properly, this isn't a deal-breaker.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 12-17-2008, 07:19 PM
Jeff R's Avatar
Thanks. I was expecting more brake travel but I tested things out. I could move the fuselage and, when I sat the parking brake, it wouldn't budge.
So, yeah, I am done!
Jeff Rosson
Repeat Offender
VAF Number: 1170
