Old 12-16-2008, 06:05 AM
dustman dustman is offline
Default baffle seals
Here is one for the experts, Is it necessary to have a baffle seal where the air box meets the cowling? I have about a ? of clearance between the air box and the cowl. Why wouldn?t a bead of silicon at the junction of the two surfaces work, if a seal is needed? I?m going to put the baffle seal in the old fashion way but was curious about other alternatives.
Dustman
RV3B
St Marys Georgia
Dues paid 11-11-2011
Old 12-16-2008, 06:38 AM
Ironflight's Avatar
VAF Moderator / Line Boy
There is a lot of relative motion between the airbox and the cowl - I think that you need the flexibility of baffle seals to let things move around.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-16-2008, 08:35 AM
flion's Avatar
flion flion is offline
And you'll probably want more clearance or getting the cowling on and off is going to be a pain. I've got about 3/8" and am thinking of trimming the cowl a bit more.
EAA Technical Counselor #5357
Old 12-16-2008, 09:28 AM
JonJay's Avatar
JonJay JonJay is offline
Default Here is a trick to help...
Mount your baffling material on the sides and bottom of the snoot only, wrapped around like a "U". Attach a straight piece to the Air Box to seal the top. This makes it much easier to put the Cowl on and off.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 12-16-2008, 09:39 AM
Brantel's Avatar
Brantel Brantel is offline
What is the best attachment method to get the material fastened to the snoot?
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 12-16-2008, 10:13 AM
JonJay's Avatar
Default Varies....
I believe the plans call for large washers and pop rivets similar to the Engine Baffle and Cooling Ramp. I used screws with a nylon washer, large washers on the back side with locknuts. I used pop rivets on the Air Box piece.
Bucker Jungmann
RV1 - Proud Pilot.
Old 12-16-2008, 11:04 AM
Brantel's Avatar
Bolts and washers....Ok.
I doubt one could get a pop rivet gun in there so that must be the way to go....
Old 12-16-2008, 12:39 PM
szicree szicree is offline
FYI: the seals go on the airbox, not the cowl.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 12-16-2008, 12:51 PM
Brantel's Avatar
Not if you want to follow JonJay's advice.......
His idea is to have a U shaped piece on the cowl snout and a flat piece on the airbox top. When together they makeup the seal. This makes the cowl easy to lower down away from the airbox.
The plans and directions show the seal attached to the airbox but the smart people here at the VAF have deviated from the directions.
Old 12-16-2008, 01:10 PM
DanH's Avatar
DanH DanH is offline
<<The plans and directions show the seal attached to the airbox but the smart people here at the VAF have deviated from the directions.>>
Assume pressure at the intake opening of the lower cowl is higher than pressure inside the lower cowl (and it probably is). Why install a flap seal backwards so it leaks under pressure (loss of manifold inches), and raises lower cowl pressure (bad for cooling) in the bargain?
Dan Horton
RV-8 SS
Barrett IO-390
