I bought the single channel dimmer from
www.pilotlights.net and installed it to control my rockerswitches and radios. Very simple connections but it doesn't do anything. I know power from the lights is going to it because If i unhook the wire from the dimmer the lights on the rockers go out. The lights are on full all the time even if the dimmer is in the off detent position.
The dimmer shares a common ground and that is the only thing I can think that might be the problem. Maybe they need their own ground wires but I cant imagine this being the case.
Anyone have any exeperience with these dimmers?
