I am doing my first condition inspection on my R9A this month and I wonder if I should check on the torque on all nuts and screws that can be seen when the cowl and inspection plates are removed? When I installed the bolts originally I marked each one with red finger nail polish to indicate I had torqued them. However, the marks were not done lineally across the bolt and nut in some cases. So those I can't determine if they have moved since installation.
I have done a search of the inspection check list threads and this was not addressed.
Cleve Thompson
Waycross, GA
Flying a RV9A with O-320 from KAYS
since Dec 2007 & having a blast
