Old 12-13-2008, 02:00 PM
cbo111's Avatar
cbo111 cbo111 is offline
Default Off-airport landings
First, I gotta say this site is an amazing source for flying techniques, maintenance and building tips, and a host of other valuable information. So maybe some of you can help answer a question that for some reason I have been pondering lately. In 20+ years I've been lucky enough to never be forced to land off of an airport runway. The question is, what would I do if I was forced to make an engine-out landing to some road or highway a couple hundred miles from my home drone? Who would I call, is there a service out there that transports intact aircraft with blown engines? Anybody with experience out there, I would be interested in your story.
regards,
Chuck Olsen
RV-7A
Tehachapi, CA
Old 12-13-2008, 02:07 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Interesting question. When a local 182 landed in a field several miles away due to a poorly installed oil filter assembly, numerous local folks helped. A tow company with a flatbed that tilts down was used to transport it back to the airport it along with the local sheriffs office.
Old 12-13-2008, 02:12 PM
Jamie's Avatar
Jamie Jamie is offline
With RVs people generally just pull the wings on-site, load it on a flat bed trailer or flat bed tow truck and bring it back to the airport (after NTSB/FAA release it of course).
Old 12-13-2008, 02:13 PM
born2fly's Avatar
born2fly born2fly is offline
Default Different places
I forget exactly where it was, Washington state I believe, where a Cessna 210 landed on a road due to fuel starvation.
They gassed up the airplane, the Sheriff and local fire department closed off the road, the 210 took off but miscalculated its takeoff roll and hit one of the fire trucks parked alongside the road, hooked right and ended up in a ditch.
Nobody hurt, but lots of lessons learned.
I've personally (intentionally) landed off-airport multiple times. I always have that nagging thought - - - what happens if it won't start again? So far, I haven't found out.
G.
______________
Greg Illes, RV6 - N164JH
RHV, San Jose CA
Old 12-13-2008, 02:15 PM
Ron Lee's Avatar
Greg, I think I saw that video. Another case of poor judgment/prudent check of everything before take-off.
Old 12-13-2008, 02:31 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by cbo111 View Post
... The question is, what would I do if I was forced to make an engine-out landing to some road or highway a couple hundred miles from my home drone? Who would I call, is there a service out there that transports intact aircraft with blown engines? ...
Chuck,
First call would be to Doug and ask him to check his list to find out if there are any local RV'ers close by. Second call would be to the EAA national to get the number of the local Chapter.
Between those two contacts, you should have no problem getting the plane either fixed or back to an airport where it can be fixed.
As a former EAA chapter president, I have helped with everything from a B-17 to C-150. The chapters are a great resource and are worth the cost of membership in the national.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-13-2008, 02:40 PM
tomwebster's Avatar
tomwebster tomwebster is offline
Default Remove the wings!
I had to move my 7A from a clover field
to my hangar about 40 miles away.
(There was no damage other than
where a cylinder tried to come through
the side of my cowling.)
I removed the wings, it's much cheaper.
Otherwise, you have to close the roads
do to the wide load specs.
To move it with wings on, ODOT wanted
me to hire two off duty patrolmen plus
pay rent on their patrol cars. Over $3K
not counting using an 'approved' wide
load carrier. The roads would have been
closed in sections.
My route had to use US and State highways.
Anything over 12' wide and you are out of luck.
Tom
Tom Webster (Chox)
VAF-134
Columbus, Ohio
Luscombe 8A/E (sold after 35 years)
RV-7A N462TW (315 hours)
CX4 (under construction)
Friends of the RV-1 http://www.rv-1.org/
Old 12-13-2008, 02:52 PM
gbrasch gbrasch is offline
Guest
The first thing I would do is call 911, to let whoever know if your ok (or not), and to cover your butt......then fill out a NASA form....
Old 12-13-2008, 05:32 PM
cguarino cguarino is offline
Default Louisiana
G.
It happened in South Louisiana.
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
Old 12-13-2008, 05:47 PM
Geico266's Avatar
Geico266 Geico266 is offline
This is a little off subject, but relevant. I was looking at buying a flying RV-6 to renovate the panel over the winter and asked a local FAA Safety Inspector if I could legally land on the road in front of my house. It is an interesting question, and he found out it depends on local regs. The FAA really didn't care as long as local laws were not broken. In Nebraska, I could legally land the plane on the road (in the country) if we call the county sheriff first and to get "permission". Take off (after renovation) would be the same thing. I would imagine the first time I did it there might be a "fee" for having two deputies to block off the road.
So the answer was; It depends on your local law enforcement and how much they see it as a risk, and (after reading about the Cessna hitting the firetruck) what their experience has been.
More on point to your question if I was a ways away from my home airport I would contact the nearest EAA chapter and ask for help, if no VAF members were close.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
