I’ve been getting a lot of inquires on the G3i Ignition system and the interface / install modifications on existing magnetos (Slick and Bendix mags). If you go to
www.g3ignition.com and go G3i installation instuctions page. The latest full version of the complete installation manual in a 1.5mb pdf. file for you to view. The latest testimonial I received from Brandon Jewett was his fuel economy on a flight of 2 RV-6’s going down to NM. To identical RV-6’s flew together, same engines"0-360-A1A and Hartzell CS 76" props. Both lean identically for cruise. The trip was 239 nautical miles at 11.500ft at 170k indicated. Brandon had a passenger and was 400lbs heavier than the other RV-6 and burned 20.1 gallons of fuel with the G3i Ignition system, while the other with stock Slick mags. burned 25.1 gallons. Wow. Larry Vetterman of “Vetterman’s Exhaust Systems” is still in conducting his flight-testing of new prop and exhaust systems along with the G3i system also. Those results will be available soon. Check the manual out and if you have any questions, I’ll be happy to answer them.
Sincerely,
Thomas Shpakow
Generation 3 Ignition
www.g3ignition.com
