Old 12-13-2008, 08:06 AM
robjohnson's Avatar
robjohnson robjohnson is offline
Default Duckworks rectangular light size
After about 48 hours of flight time, my taxi light bulb blew (I have wig wags and run them constantly). Well, in my infinite wisdom and attempt to replace the bulb, I ruined the reflector/bulb socket. I didn't know until after the face that there is a screw on the back side that needs to be loosened to release the bulb.
Does anyone know the brand or size of the rectangular lights used in the Duckworks kits? I did some rough measuring yesterday of the reflector, but I didn't write it down (I was honked off because I ruined the stupid thing). I'd like to swing by an auto parts place on the way to the hangar today, but I don't want to get the wrong size.
Any ideas on the size??
Rob
Rob Johnson
Bloomington, IL
RV-7 N826RC - sold
1945 Piper J3 Cub - sold
RV-10 - wings with fuselage ordered
https://www.rv-builder.com
Old 12-13-2008, 10:10 AM
Randy Hooper Randy Hooper is offline
Default WalMart Aviation Supply
Go to WalMart. Look for the rectangular quartz light like you would mount to a truck bumper. $10 or $15 for a pair as I recall.
Randy Hooper
Old 12-13-2008, 01:48 PM
intothinair's Avatar
intothinair intothinair is offline
Default Duckworks Halogen light repair
These halogen lights are often on sale for less then $9 for the pair. The parts may be useful to repair your Duckworks lights.
http://www.harborfreight.com/cpi/cta...emnumber=37349
Old 12-13-2008, 02:13 PM
tomwebster's Avatar
tomwebster tomwebster is offline
I still have the case that came with the Duckwork
lights.
It is approx. 5-1/2"W x 2-3/4"H x 2" D
No numbers on the case.
The lens has HALOGEN on one end
and SAE-Y-86 on the other end,
molded into the lens.
Tom
Tom Webster (Chox)
VAF-134
Columbus, Ohio
Luscombe 8A/E (sold after 35 years)
RV-7A N462TW (315 hours)
CX4 (under construction)
Friends of the RV-1 http://www.rv-1.org/
Old 12-13-2008, 02:44 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Last time I was there, I too noticed that some of the ones at Harbor Freight look identical to the Duckworks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 12-13-2008, 02:52 PM
tomwebster's Avatar
The HF ones I have seen are not wide enough
and I would have had to modify the mount.
Tom
Tom Webster (Chox)
VAF-134
Columbus, Ohio
Old 12-13-2008, 05:34 PM
robjohnson's Avatar
Thanks for all of the suggestions and replys, and thanks, Tom, for the exact dimensions of the duckworks light. Absolutely perfect!!!
Rob Johnson
Bloomington, IL
RV-7 N826RC - sold
Old 12-14-2008, 05:43 PM
DickDe DickDe is offline
Default Duckworks Reflector
I just installed a Duckworks halogin landing light which came in an orphan wing kit originally delivered in 2002. That kit had a Hella brand running light which was disassembled to obtain the reflector. No model or other info was there.
Dick DeCramer
Northfield, MN
RV6 N500DD 300 hrs.
RV8 wings complete
Old 12-14-2008, 07:30 PM
robjohnson's Avatar
Default Got a reply from Duckworks
Man, do I feel like an idiot. In parallel to this thread, I sent a note to Duckworks explaining my problem and asking if I could purchase a single light to replace my broken one. Thankfully, they were able to identify that I didn't actually break my light -- I just ruined my bulb (it was already broken). It seems that the replacement light comes with a new socket and wire, as well. The wire I was seeing broken through the socket is the one that comes installed with the H3 bulb assembly. Stupid, stupid, stupid!!! The good news is that a $4.99 bulb fixed the problem!
Rob Johnson
Bloomington, IL
RV-7 N826RC - sold
Old 12-14-2008, 08:57 PM
Rupester Rupester is offline
Default Brave man
Rob,
...you get 10 Karma points for admitting your mistake to all of us.
Terry
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
