Old 12-12-2008, 01:33 PM
db8's Avatar
db8 db8 is offline
Default Switch Relay Questions
Have tried to figure two things out, but haven't been able to. First, I will have an avionics switch that I want to run more amps than the switch can handle. Where is the best place to get a high quality, light weight relay that will work for up to say 30 amps in this application. Second, I have some lighted switches that are really neat that are rated at 5 amps, but I want to use them for landing lights, taxi lights, pitot heat, strobes, nav lights etc, but those are all more than the 5 amps. Once again, where is the best place to get high quality, light weight relays that will work for say 10 amps. All the ones I have found are kind of large and heavy (ice cubes they call them). I have seen some that Bosch makes, but they are inexpensive and I don't know about the quality. Thanks for any help on this. Dave
Dave Buntin
http://i55.tinypic.com/iny6qa.jpg RV-8, N 130YS, BOYS & TOYS
[size="1"][color="Blue"]
Old 12-12-2008, 03:56 PM
DGlaeser DGlaeser is offline
Default Relays
I have a couple of Bosch 'ice cube' 40 amp relays that work just fine. I forget where I got them but a google search brings up lots of choices like this: http://www.boardrelays.com/?gclid=CJ...FRdLbQodTltbSw
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 12-12-2008, 04:09 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
I used several Tyco VF4's in my -6: http://relays.tycoelectronics.com/telectronics.asp, one of which for an avionics master. OEM's use these relays to activate airbags, among other critical things, so quality shouldn't be too much of an issue.
However, I also installed a bypass switch/breaker (30A) to power the avionics bus, which I mounted with a red switch guard on the far end of my switches. This breaker gets its power directly from the battery, so I can power my efis and radios when the master contactor is off.
If you want to see my wiring diagram, send me a pm and I'll get you a pdf.
Heinrich Gerhardt
RV-6, flying.
