Old 12-12-2008, 11:05 AM
vonjet vonjet is offline
Default Humming noise in headsets
My airplane is newly wired. I plug in my headset (Bose) and there is a humming noise in the background unless I touch the avionics tray or any ground point on the airplane. It goes away. It also goes away if I touch the mic jacks. Is there something wrong? Bad ground somewhere?
Old 12-12-2008, 11:23 AM
Jamie's Avatar
Jamie Jamie is offline
Are you using the panel power jacks or standard headset jacks? If you're using standard headset jacks, are the mic and earphone jacks isolated from the airframe?
If not, pull the headset jacks away from the panel and let them hang free from touching ground and try it. If it works that way, you just need to get some of these washers.
Old 12-12-2008, 11:34 AM
Default Standard Jacks
The jacks are not mounted to anything yet. They are just hanging in the baggage compartment. I read that the audio wires dont like being next to the coaxial wires for the antenna. Mine all run down the center of the airframe. Maybe they dont like being next to each other.
Old 12-12-2008, 12:35 PM
DanH's Avatar
DanH DanH is offline
<<there is a humming noise in the background ..>>
Does it sound like "Hi ho, hi ho, off to work we go"? Sometimes I hum that when I'm in the shop and happy <g>
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-12-2008, 12:44 PM
Default I wish
But its not coming from me....its a noise I dont want to hear.
Old 12-12-2008, 12:56 PM
Jamie's Avatar
Are the wires running to the jacks shielded? If so, are the shields grounded at the intercom? Did you try turning everything else off except for the intercom?
What intercom are you using? What type of plane is this? Many intercoms have a limit for how long of a run you can make to the headset jacks.
Old 12-12-2008, 01:06 PM
lrfrey lrfrey is offline
The antenna coax running along with the audio wires should only be a problem on transmit, and I have seen numerous installations where it was no problem at all.
Mine actually run together for about 6 feet, and are seperated for the next 4 feet, when they were together for the entire run they squeled like a stuck pig... (on transmit).
Sounds more like a ground problem. You didn't say what radio or intercom you have, but most have a wire from the connector directly to ground and don't only rely on the case frame. Also check tht the wires on the jacks themselves are valid. Do you have the same problem with both jacks (pilot and co-pilot) or just one?
Larry
Old 12-12-2008, 02:20 PM
szicree szicree is offline
I know it's a long shot, but is your power source "clean"? I made the mistake of powering mine up with a battery charger and it hummed like crazy.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 12-12-2008, 11:19 PM
Default power is from the A/C battery
the audio panel is garmin 340. I think I found the problem. I need to run a ground wire from my jack mount. I heard the Bose headsets are so sensitive this can be a problem.
Now I just have to figure out my dimmer issue.
