Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 12-12-2008, 03:19 AM
dlomheim dlomheim is offline
Default Question For Ross re. spinner...
Ross: What brand of spinner are you using on your "6A" with the IVO prop? Also, did you mount the spinner ahead of the prop or behind it? I will be using an IVO as we have discussed in the past but need to get a spinner installed this summer and I'm leaning towards the UHS sold by Spruce.
Thanks for any info.
Doug Lomheim
RV-9A, 13B, FWF, canopy, electrical, etc, etc
Old 12-12-2008, 08:43 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Using the standard Vans part. There are some details and photos here: http://www.sdsefi.com/rv9.htm
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 12-12-2008, 02:48 PM
Default Spinner, etc.
Thanks for the link Ross!
dl
