Old 12-11-2008, 02:53 PM
Windrunner Windrunner is offline
Default Attitude IndicatorDegree Tilt
I'm trying to determine what degree of tilt attitude indicator I should buy for my RV9. I've been told to measure the angle across the main longerons when on the wheels but am seeking other input. Thanks in advance.
Old 12-11-2008, 03:03 PM
Mel's Avatar
Mel Mel is offline
I believe the instrument panel angle is supposed to be 8 degrees.
Actually mine measures about 7.5.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-11-2008, 03:08 PM
Thanks for the reply Mel. Should I measure using a reference across the instrument panel then with the weight on the wheels? Thanks again.
Old 12-11-2008, 03:15 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Most mechanical attitude indicators will be sold as 0 or 8 degree. The 8 degree will be close enough.
L.Adamson --- RV6A
Old 12-11-2008, 03:29 PM
Thanks for the input. I'll go with an 8 degree unit.
