Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 12-11-2008, 02:31 AM
Camillo Camillo is offline
Default 430 and European card
Hi. I don't have enough infos on Garmin GNS430 so I am asking.
I live and fly in Italy where WAAS is not available. So I guess I will buy a GNS430 non WAAS to save money. Maybe used from a Vansairforce member, if available.
Prior to making a WTB, I would like to know if data card which is included in a USA 430 covers all the world or only America. If the latter, how much approx. will cost a Euope card.
Another question is the harness. Do I need a pro to install or can I do it myself?
Last question. Is there some version I should look for (i.e.: higher power CPUs for further WAAS upgrade, etc...) or does this make no difference?
Thanks.
Camillo
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 12-11-2008, 08:42 AM
sjhurlbut sjhurlbut is offline
Default 430/430W
Thanks.
Camillo
I have a 430 coming up for sale very soon. I have upgraded to WAAS so this non WAAS unit is for sale. Unit is 2 years old (bought new) and I have 250 hours on my airplane. Includes antenna, wiring harness (you still have to solder it together), tray, backing plate and manual.
You need a European card. You can buy one directly from Jeppesen or download the database using Skybound. One time download will likely be around ~$130?
Reference wiring. Depends if you think you can wire it or not. I would suggest asking for assistance if you're not sure. I use Approach Systems harnesses and love them.
Version numbers? The CPU upgrade is part of the WAAS upgrade. You won't find it on its own. So the short answer is no. There are software updates but no hardware updates unless to get the full WAAS.
Steve
RV7A
C-FSIS
Old 12-11-2008, 11:08 AM
Default Thank-you
Complete answer. And glad to know you will sell it shortly.
Ciao.
Camillo
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
