Old 12-10-2008, 08:19 PM
Mark7986 Mark7986 is offline
Default Help!!! Riveting bottom skins
I'm ready to rivet the bottom wing skins on my RV7. I have clecoed the inboard skin on several times. I just can't figure out where to start or how to start. Any suggestion would be welcome. They say pictures are worth a 1000 word. If someone has a series of pics I would love to see them.
Mark Craven
Fairmont, MN
Old 12-10-2008, 08:38 PM
N941WR's Avatar
N941WR N941WR is offline
Start in the middle of the trailing edge of the inboard skin. Work towards each end of the skin and then down. We went down six to eight rivets on each rib. That way could still bend the skin up enough to rivet in place.
Here's a picture of when we first started one of my bottom skins:
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-11-2008, 10:00 AM
n2prise's Avatar
n2prise n2prise is offline
Default Lower wing skin riveting
Look at this web page about half way down. Photos and text explain it. http://www.n2prise.org/rv9a014.htm
Jerry K. Thorne
Built in East Ridge, TN.
Now in Palm Bay, Florida
RV-9A - - N2PZ
www.n2prise.org
Old 12-11-2008, 10:12 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
What Bill said. Start at middle trailing edge of skin. Work diagonally both directions toward inboard and outboard leading edges. Not too tough. It takes some contortion, even with two people, but it's very doable. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 12-11-2008, 10:39 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
I did the RV9 wings by myself - pretty easy. The wings were still in the stand mounted vertically and that helped a lot. I first did the whole trailing edge, then worked slowly up the ribs to the leading edge. By the end, you'll be figuring out as you go what to rivet when to preserve access. The last few rivets are bucked through the ends of the wings, and the access panels.
The -9 wing has less chord, so it may have been easier in some what though.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 12-11-2008, 03:01 PM
aparchment's Avatar
aparchment aparchment is offline
Default Wing Riveting
I did the 7 wings by myself. It was a pain, but definitely workable.
I started like the others said - at the trailing edge and worked my way up the ribs. I would work within a bay and do the ribs on each side of the bay, then move to another bay. Once I got within 5 or 6 rivets of the spar I switched to bucking through the lightening holes.
I also riveted with the wings in the vertical position. I don't think it is possible to reach otherwise if you are working singlehanded.
Antony
RV-7A
Empenage complete, wings complete, tip-up canopy complete, starting wiring ...
Old 12-12-2008, 04:50 PM
Default Thanks
That gives me a better idea how to start. thanks for the help.
Mark
