12-10-2008, 11:34 AM
countersinking fuel tank skin
I'm about to countersink the tank skin to baffle fit on my 7A fuel tank. Should I go a couple thou deeper to allow for the proseal? It would seem to coincide with the logic of using fuel tank dies. right?
Robb 7A
12-10-2008, 11:40 AM
If I had it to do over I would.
Several of my rivets on the baffle will need to be shaved before paint due to them being proud of the skin.
12-10-2008, 11:41 AM
Robb,
Here's one data point...I didn't go any deeper than recommended by Vans. IIRC, the skins are 0.032", which is the bare minimum for countersinking to accomodate an AN426 rivet. My skin-to-baffle rivets actually sit a little proud because of proseal, and I figured that was better than making deeper countersinks.
There's some good information in this thread...
http://www.vansairforce.com/communit...ead.php?t=2322
about your question.
Hope this helps,
Dave
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
I did, and probably would go a little more still if I did it again...can't tell you precisely how many more thousandths, but I did increase the depth a few...
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
12-10-2008, 11:58 AM
Im afraid of violating the .032 rule Dave thats why I'm asking............but if there is proseal in there do you think it would really matter.....
Brian...... I've never heard of a rivet shaver I dont think.......I remember having to sand down a couple of blind rivets on the emp during fiberglass work....they came out just fine.....but they are under glass work..../so no biggie............so if I get some proud rivets, this rivet shaver will take em down before paint?
12-10-2008, 03:00 PM
This is interesting, I dimpled all mine, with proseal on all the rivets. Is this wrong, I don't think so. I know this has been talked about before and I was told this is wrong. But it says in the manual, not the plans, to dimple all tank skins. So I did. It looks good and it doesn't leak. I think dimpleing is stronger and less chance of a crocked hole, or a line in the hole for a leak. I'm not reduing mine, they stay the way they are. I even remember reading one of the tool suppliers having a dimple die for tanks to make the rivet set lower for proseal.
12-10-2008, 03:03 PM
I think we are talking about the skin to the baffle rivets. I also dimpled all the others.
12-10-2008, 03:36 PM
I didn't on my first tank, and most of the rivets ended up a little proud. I went slightly deeper on the 2nd tank and it came out perfectly.
12-10-2008, 04:50 PM
Yes, go slightly deeper
I just did my skin holes for the baffle and I made the countersinks so that the rivets were flush or even slightly indented, but after riveting with Proseal, I have many that are slightly proud and I'll have to smooth them off later. You can see them at mykitlog/sglynn
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
12-10-2008, 06:04 PM
On my 9A, I countersunk the main skins for the baffle rivets in the .032 skin per directions. For my auxiliary outboard tanks, the skin is .025 so I dimpled them with the tank dies. The rivets set beautifully in both, and I will be pressure testing them this weekend. I'll keep all here advised.
