Old 12-10-2008, 07:06 AM
rwayne rwayne is offline
Default Electrical Tape
Anyone know of a source for 2" electrical tape, or some other suggestion for what to use to protect the plexi when glassing and sanding? Thanks.
Old 12-10-2008, 08:03 AM
DanH's Avatar
DanH DanH is offline
Blue 3M vinyl Fineline tape works well for the edge, then just overlap it with ordinary masking tape to attach a mask to the rest of the plexi. I used 4 mil plastic sheet inside and out, with a foam pad on the top so the whole assembly could be flipped on its head to work on the inside.
Black electrical tape is cheaper than Fineline, but may creep if stretched too tight and I'm not sure about solvent resistance when you get to painting. Whatever works. Either way, you don't need 2"; lay a strip of ordinary 3/4" to define the edge then lap over it with the mask. To bend around a small radius curve you might use an edge-defining tape as narrow as 1/8" and then lap it with masking tape.
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-10-2008, 08:34 AM
Vern's Avatar
Vern Vern is offline
Default Tape options
I prefer the ordinary cheap electrical tape. Use multiple layers and overlap. Hold up well to create a sanding edge. It handles curves well.Great on windshields!
Spruce sells a 2" blue vinyl-type tape for about $23 /roll that I've used.
Do a search for 'tape' on www.aircraftspruce.com You will see a lot of options.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
