Old 12-09-2008, 09:34 PM
SteelMike's Avatar
SteelMike SteelMike is offline
Default Fuel Tank Tools
Hey guys,
I'm starting to work on fuel lines (in the fuel tanks, that is), and I need your help selecting the correct tools.
I'm looking for an affordable tube flairing tool. Is this what I want (?):
http://www.aircraftspruce.com/catalo...ringtools2.php
I'm also looking for a pipe cutter. How about this one? This one includes a fold-away reamer to remove the burr, right, or do I need a separate reamer (if so, can you recommend one?):
http://www.aircraft-tool.com/shop/de....aspx?PageNo=1
How about a tube bender? This one sounds like a good deal:
Finally, is it worth buying a tool for safety wiring?
If you guys can lend me a hand selecting tools, I'd really appreciate it.
MB
Old 12-09-2008, 10:02 PM
RatMan RatMan is offline
Looks to be the same as the one I used, not sure if it is as it was a loaner.
That will do but I used one a lot smaller, not better but smaller. Like this one from RIGID. You'll need a larger one for the control tubes (elevator/ailerons) though.
Almost exactly what I'm using, but this looks a bit better than mine. Good price too.
As apposed to twisting it without a safety wire tool? Absolutely! And of all the tools you have mentioned, you'll use it much longer and more often. Like every time you change your oil. I use safety wire pliers often.
John Ratliff
N898R
RV-8
Saucier MS
Old 12-09-2008, 10:52 PM
SteelMike's Avatar
Thanks for the tips. Can you recommend a safety wire tool, too, then? It appears there are a lot of options and I know nothing about safety wiring (someone's gonna mention AC 43.13 soon).
By the way, what about reamers?
MB
Old 12-10-2008, 03:00 AM
Here's what I have...with automatic return.
Here's a quick down and dirty I found using Google, they even mention 43.13.
Even has pictures.....
I haven't used reamers but I'm sure someone will help out with this.
John Ratliff
N898R
RV-8
Saucier MS
Old 12-10-2008, 04:49 AM
rleffler's Avatar
rleffler rleffler is offline
While not required, reamers do a better job at cutting a nice hole with minimal distorations. Take a look at a hole finished with a drill bit and a reamer under a magnifying glass. The reamer hole will be cleaner.
I use a reamer whenever possible for match drilling, unless one piece isn't already pre-punched obviously. You'll get plenty of use out of a #30 and #40 reamers.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 12-10-2008, 05:31 AM
RV6_flyer's Avatar
MB
Here is a FREE Soft copy of AC 43.13-1b with change 1. See Section 7 for info on safety wiring.
http://rgl.faa.gov/REGULATORY_AND_GU...E?OpenDocument
And a paper copy for sale.
http://www.skygeek.com/js312617.html
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 12-10-2008, 08:51 PM
SteelMike's Avatar
Thanks guys, already have a copy of AC43.13!
By the way, when I said reamers, I talking about the type that will remove a burr on the inside of the tube after cutting. Not sure what the correct term is for these. Anyone know what I'm talking about?
Thanks a bunch, as usual.
Old 12-11-2008, 06:19 AM
Mel's Avatar
Mel Mel is offline
Default Believe it or not...
with a little practice, an Exacto knife works great on aluminum tubing.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
