Originally Posted by rwarre
I am using the Z11 diagram for my RV 7A, Lycoming o320. I bought the mag switches and both are spring loaded, (2-5). My question is why would I need both switches to be spring loaded when only the left switch is used to start the engine. (only the left mag is impulse coupled)
The right mag switch doesn't need to be spring loaded, but I went with them both being the same to keep it simple and to have a fewer parts count.
As installed both switches are momentary up and maintained down.
As wired the right mag switch momentary up position does nothing.
I probably should pick up a spare (2-5) switch to put in my tool bag.
Mark
