Old 12-07-2008, 04:14 PM
rwayne rwayne is offline
Default CH Products Grip
I've heard that there is a new source for what was the CH Products control stick grip. Anyone know if there is a source? I really the grip is ambidextrous.
Old 12-07-2008, 04:21 PM
Chappyd Chappyd is offline
http://www.tostenmanufacturing.com/
Here ya go . I ordered a pair last week. Haven't gotten them yet, but I like the fact that they are symetrical too
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
Old 12-08-2008, 08:42 PM
Default Thanks!
That's what I'm after. Thank you!
Old 12-09-2008, 05:05 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default Tosten Grips
Installed a pair in my 9A last week. Really nice. Highly recommended!!
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 12-09-2008, 07:07 AM
Camillo Camillo is offline
Default Need relay?
Hi. I am about to order a couple of Tosten stick grips. I am not sure if I need their relay deck (or Ray Allen relay deck) or if I may order their grip with built in relay. I would like to have elevator servo commands in both grips and would like pilot/copilot to work without having to push a switch.
Thanks.
Camillo
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 12-09-2008, 07:56 AM
craigvince's Avatar
craigvince craigvince is offline
Default You'll need a relay
You'll need a relay, either internally in the stick or somewhere under the seat or panel. It's really up to builder's preference. Having opted for the external relay myself, I wish I'd just paid the extra for the internal relay.
Old 12-09-2008, 11:41 AM
I wrote to Tosten and received this answer.
"If you are wiring duel controls you will need the cs-8 with out relays and one external deck. I install the one in the grip so if you are only using one
grip for trim is makes it easier to wire up."
I'm afraid I didn't understand everything. Does this mean that I need an external relay (relay deck)? Above, Craigvince wrote the opposite. If I can go with internal or external, I will need two CS-8 with built in relays. I understand this is good for wiring, but is it also good for further repair?
Thanks.
Camillo
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
