Old 10-18-2005, 04:50 AM
StuartAberdein StuartAberdein is offline
Default Glider towing and rough field operation
I am thinking of buying an RV-6 or RV-7. Two questions..
1. Would an RV-6 or RV-7 be suitable for glider towing?
2. Our field is quite rough grass. How well would an RV-6 or 7 handle this. The wheels look a bit small. Can they be modified to take larger wheels?
Thanks.
Old 10-18-2005, 05:03 AM
1) Check the FAR's on glider towing by experimentals. I seem to recall that it is prohibited.
2) The small wheels make for a rough ride on a rough field. Once upon a time, Van's prototyped mounting larger wheels, but nothing came of that...
Old 10-18-2005, 05:04 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Default Definately not
Although it might be a suitable plane, the operating limitations specifically prohibit it by default.
You might be about to get a new set issued for specific testing purposes but I am no expert here.
Best,
Kahuna
Old 10-18-2005, 08:14 AM
Ann Ann is offline
Glider towing and intentional parachute jumping are specifically prohibited for amateur-built aircraft. Exceptions can be petitioned for to the local FSDO. I know of instances where parachute jumping has been approved for suitable aircraft, but I don't know of any glider towing approvals.
BTW Now that I am retired, my login shows up as "ANN" since I am logged on from the home computer. Haven't figured out how to change this yet.
Mel...DAR
Old 10-18-2005, 08:34 AM
McFly's Avatar
McFly McFly is offline
Default Aside from the legal stuff
The stall speed of the RV is 15+ mph higher than the tugs usually used. Towing at a comfortable speed for an RV would be getting towards the upper end of the envelope for most Schweitzers and other ships with low L/D.
Also I would not subject my RV to the punishment of a rough field on a daily a basis eigher.
Pawnees seem to be going for a song and would be much better suited for your mission. Good luck.
Old 10-18-2005, 12:46 PM
hngrflyr hngrflyr is offline
Another consideration in towing gliders is, at glider towing speed you're not getting enough cooling air through the engine to properly cool it. This past summer, I tried flying our RV-6 across the Cascade Range in Oregon along side a couple of friends who were flying an N3N and the other in a Stearman. I couldn't keep the cylinder head temp out of the red without speeding up and getting some air going through it. It was a warm morning, about 75 degrees at 8000 ft.
Bob Severns
Old 10-18-2005, 01:04 PM
rrrob rrrob is offline
I have considerabel experience towing and agree with the above posts. You would need something like a Bearhawk for the type of operation you suggest, or a Murphy Rebel or Moose if you wanted metal.
rrrob
Old 10-18-2005, 03:09 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default No go
rrrob
rrob I think you missed experimental aircraft are not allowed to do glider tow / jump plane Ops, Bearhawk, Moose or RV, regardless. G
Old 10-19-2005, 12:07 AM
Thanks to all of you for your input. I live in South Africa and there is no prohibition on glider towing for homebuilts here. Quite a few people do it, mainly with the East European Rotax-powered ultralights and it seems to work well. I know it is OKed in Germany too. However what people say about the stalling speed being too high makes sense so I will have to think again. Thanks.
Old 10-19-2005, 05:54 AM
N941WR's Avatar
N941WR N941WR is offline
Default There is always the RV-9/A
Stuart,
There is always the -9 series. The lower stall speed and 160 hp engine w/ CS prop should work fine. The cooling might be an issue but you can fix that easily enough.
I know of at least one RV-4 in Germany that is used for glider towing so...
Before someone asks, the German who built the RV-4RG uses his stiff legged -4 for as a glider tug.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
