Question about wing attach bolts
Question about wing attach bolts. I am installing the wing on my RV6A, all of the close tol. bolts when in well (did not need to drive them in just tap with plastic mallet) now I am putting in the AN3-15A,16A,and 17A,s I have been in the habit of placing a washer under both the bolt head ( feel it gives a larger bearing surface) and the nut but I am concerned that the shank does not protrude from the hole, I have plenty of threads though, approximately 4 ? 6 threads show after the nut is tightened. Knowing that the threads will not bear weight, should I leave the washers off under the bolt head and only place them under the nut, I have also been facing the bolts to the rear of the aircraft where I can, would this be correct.
Thanks all, were getting there.
John Collins
South Central PA
RV6A Phase II
