12-03-2008, 04:54 PM
Straight Tire Chuck
Does anyone know of a place to purchase a 4-5" straight tire chuck to air up the tires with the wheel pants still on?
I've been looking at local automotive specialty shops and no one has them. It can't be that hard to find.
Thanks in advance!
12-03-2008, 05:40 PM
Gary Bricker
Northern tool or a good auto supply (not AZ) get a Milton brand S-516
12-03-2008, 05:45 PM
12-03-2008, 05:46 PM
Super Moderator
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
12-03-2008, 06:53 PM
You can also screw two of the regular metal extensions together with some Loctite. I did this and it works great, for about $6.
Alan Carroll
RV-8 N12AC
12-03-2008, 09:52 PM
I trimmed the clamping device off this one from Harbor Freight, and it works. Would be a little nicer if it was stiff, but I'm able to service tires through a 7/8" hole in the wheel pant. The gage was inaccurate and I placed some calibration marks on the dial. I should probably break down and buy a new gage for it.
http://www.harborfreight.com/cpi/cta...emnumber=95583
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
12-03-2008, 11:30 PM
For around the hangar, I grabbed one of these Amflo inflators ($25.95) from toolsource.com for use with the compressor. Local A&P recommended Amflo, and looks like high quality construction (metal housing, brass bar for the guage, versus plastic on the one I tried from Pep Boys first). Flexible hose works well through the fairing.
http://www.toolsource.com/tire-infla...k-p-50503.html
Picked up one of the Avery extensions for the road too!
Bob
12-04-2008, 07:45 AM
Are you guys drilling a hole in the fairing or is there a way to get at the tire fitting with out adding a hole in the fairing?
John Adams
Seattle
RV7 600+hrs
Paid 12/2014
12-04-2008, 08:03 AM
Yep....
....a 1" hole and then buy a plug at the Local hardware store/aviation dept.
I also paint a white stripe on the tire sidewall that is straight down when the valve stem is aligned with the hole. Sure makes it easier to find the stem.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
