Old 12-03-2008, 02:49 PM
Redwagon Redwagon is offline
Default Quick Q: Weight of Antenna Coax per foot?
Howdy-
Anyone have an idea of what antenna coax weighs per unit length? I'm looking at a few different antenna options and if the Coax adds up to a lot of weight I'm going to head on a different path.
Tim
Old 12-04-2008, 07:03 AM
noelf noelf is offline
Default Different Coax (RG-xxx)...
have different electrical and physical properties. The best suggestion I have is to decide what Coax type is needed, then go to the cable manufacturers web site and cross reference the coax type to the specifications for that coax. You should see an entry for weight-per-1,000 feet.
Some manufacturers are Alpha, and General Cable, but it is best to actually use the data tables from the coax manufacturer that you anticipate that you will actually use.
Old 12-04-2008, 02:52 PM
Default thanks
OK thanks I'll do that, I realize there are different types but was looking for some ballpark numbers. Will do the homework.
Tim
Old 12-04-2008, 03:46 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default ????
Originally Posted by Redwagon View Post
Howdy-
Tim
Your kidding, right?? Even all the coax you'd put in won't add up to the cheeseburger you had for lunch.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
