For #2, it's because the hinge bracket is flush with the end of the aileron. So the bolt head is actually in the gap between the flap and aileron. There should be little chance of the flap and aileron getting closer together, allowing the bolt head to impact the skin, but you could relieve the skin there for more clearance. Personally, I would not unless an inspection revealed evidence of contact. My big issue with this was that this bolt had to be installed this way because there was not enough room for the nut to be on that side of the hinge. However, if the nut ever came off, the bolt could migrate toward the flap, potentially jamming both surfaces. With no other choice, this area becomes a preflight inspection item.
EAA Technical Counselor #5357
