Old 11-30-2008, 04:41 PM
vonjet vonjet is offline
Default Wires on the Infinity Stick
Couple Questions:
Can I remove the Blue covering and foil from the infinity stick grip wires? I need to separate my wires in order for them to fit in my stick tube.
What are the 2 wires that are lose in the bundle. One is a solid metal wire type no covering and the other is a black wire. They are not hooked to anything and Not sure where they would go.
Old 11-30-2008, 06:16 PM
rene@felker.com's Avatar
rene@felker.com rene@felker.com is offline
Default Wires
I did that and had no problems....Don't know what the extra wires were for, did not use them.
Rene' Felker
N423CF RV-10 Flying
Old 11-30-2008, 06:45 PM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
The wire with no insulation is for connecting the foil shield to the airframe (physical) ground.
The black wire could then be used for virtual ground, or zero voltage potential in your avionics suite.
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
Old 11-30-2008, 07:06 PM
Default Grip
Does anyone know if It would cause problems if I didn't use the bare wire or the extra ground wire and removed the foil as well?
Old 11-30-2008, 07:09 PM
RVadmirer RVadmirer is offline
Default Ask JD
Why not ask JD? He is very easy to contact per the number and hours on his web site and is most helpful with installs on his products.
Old 11-30-2008, 07:29 PM
Default JD
I would but Im impatient and was hoping to get an answer tonight.
