Old 11-30-2008, 03:09 PM
billnaz's Avatar
billnaz billnaz is offline
Default tires, best value
Its time to replace my mains. Any thoughts on the best value for 5-5.00 tires. I'd go for cheapest normally (tightwad),but my originals from vans didn't last very long. What's the best deal out there?
Thanks to all for the posts! excelent info!
Bill
Bill Grischo, Gilbert AZ
N911WG RV-6A DVT
Flying, thinking about polishing
Old 11-30-2008, 03:18 PM
Transporter Transporter is offline
Default Aviation Consumer Tire Test
Results are on Desser Tire's website from the 2004 tire test...I haven't seen a newer one:
http://www.desser.com/epdf/ACJuneFinal04-dtr.pdf
Bottom line is that thicker tread wins (go figure!).
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 11-30-2008, 03:58 PM
RV6_flyer's Avatar
That above list pretty well sums it up for me. After 2,170+ RV flying hours, the retreads do last the longest and cost less per landing. I have been using Wilkenson retreads the past two times. Last time they were $50 delivered. It is cheaper to have your CORE retread but by the time I send them my core, it would cost more than the one with their core.
http://wilkersonaircrafttires.com/
When I need to buy new, the Goodyear lasted the longest and had the lowest cost per landing of any new tire that I have tried. All main tires on an RV need to be rotated inside becomes outside 1/2 way through to get the most life out out of them.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-30-2008, 06:36 PM
RScott RScott is offline
The April 2008 Aviation Consumer lists the Goodyear as best on a cost vs. treadwear basis because they start with more tread. Desser's Monster retread had more tread to start with but a softer compound. The McCreary Air Hawk came in a close third with a harder rubber compound, followed by Michelin, which they thought was a great tire, but with too little tread depth. If you fly a lot, they recommend the Goodyears, but if not, the tires will rot before you wear them out.
Speculation: Is a soft rubber, with more traction a good thing? I think not, especially with a taildragger. Poor traction, allowing the plane to slip a little is a reason taildraggers like grass.
Richard Scott
RV-9A Fuselage
1941 Interstate Cadet
Old 11-30-2008, 08:31 PM
AlexPeterson's Avatar
I have about 300 hours, probably a similar number of landings (or likely more), on retread Dessers. I haven't even rotated them in/out, and I would guess I'll go about another 150 hours before even needing to rotate them. The life on these will be easily 3x what I've gotten out of Van's and Michelin tires. Comparing cost per landing, the Desser retreads are only 15 to 20% of the cost of high end tires.
Only downside is that you may need to carve out the fairing openings a little to maintain clearance the same as before.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 09-08-2009, 02:47 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
BUMP to the top,
Ok I read the consumer aviation review, it looks like the Desser Monster Retreads are good.
I like the idea of extra thread since some of the unimproved strips in South Africa / Africa has got a lot of thorns on them. The extra thickness is good and it looks from the review that their is not a weight penalty. Granted I might need to open the wheel fairings a bit.
QUESTION 1) I want to know has anyone got any bad experience with the retreaded monsters, before I commit my purchase?
QUESTION 2) Giving my need for additional thorn protection I see the following monsters are available. Is the 10 Ply Better, than the Premium 2 Grove, better than standard? What about the 2 'airstop' tubes.
1)500-5 10 PLY RU 500-5 10 PLY MONSTER RETREAD @ $64.95
2)500-5 6 PLY RTM 500-5 6 PLY MONSTER RETREAD @ $58.95
3)500-5 6 PLY RTO 500-5 6 PLY RETREAD "ELITE PREMIUM 2 GROOVE" @ $61.95
4)TU 500-5 ACL 500-5 "LEAKGUARD" BUTYL TUBE (TR-67 VALVE) @ $49.95
5)TU 500-5 MN 500-5 MICHELIN AIRSTOP TUBE (TR-67 VALVE) @ $59.95
South Africa is not around the corner you know, so i need to get it right...
Thank you in advance,
Rudi
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 09-08-2009, 04:49 AM
pierre smith's Avatar
Default Hi again Rudi....
....I've been running Desser re-caps on my Air Tractors for over ten years and I've always been satisfied, as have many of my Ag buddies. Can't speak for the 500 X 5's but Desser retreads seem to last longer than new ones.
They also come pre-balanced with a glued in weight and the usual red dot to align with the valve stem.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 09-08-2009, 05:17 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default Dessers are fine
Like Pierre, I have been very satisfied with the Desser Monster retreads on my 9A. I found that they are VERY STIFF, and require some break in before they feel stable on the rollout. After installation I had a very squirrley aircraft, and even noticed more difficulty taxiing the plane. I posted here about the issue, but got no response.
What I did was lower the air pressure to about 25 psi. At that pressure, the aircraft felt perfect when the wheels were planted. After a dozen landings or so, I increased the pressure to about 33 psi (I use Nitrogen) and all is well.
You will also most likely need to hog out the wheel opening in the spat to clear the ample treads.
After about 70 landings, there is little to no visible wear on the tires yet. I like the way they feel, and they don't seem to flat spot as bad. We will see how they do this winter. Mine have GY Flight Custom hulls, and were matched nicely from Desser.
Keep in mind, I burned up a pair of El Cheapos real quick. Totally my fault. Long taxis, high landing speeds, touch and go's, and spinning to park, and failure to rotate half way through, all contribute to the poor wear I got on my kit tires. Since then, I have settled into a more tire friendly style of flying, and I have learned how to land my plane better, and slower. I don't spin into a space, and watch my taxi habits.
I can't really compare the wear on the Dessers to the kit tires fairly, as they were not given the same treatment, but I will definitely use them from now on.
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 09-08-2009, 07:27 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I order a set of tires from Desser about every 350 hours or so - just get the 500x5 6-ply retreads (I don't remember the "Monster" name - is that a new marketing gimmick?). Been using them for close to 30 years on my airplanes - very happy with them from both a lifetime and cost viewpoint! For tubes, I go with the Michelins - they seem to hold air better than the others (at east the last time I used non-Michelins about three years ago).
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-08-2009, 05:41 PM
I've now got more than 350 hours on my Desser retreads (like Paul, I don't remember that gimmicky name "Monster"), and will probably have to rotate them this winter during cond. inspection. I expect to get around 600 hours on them total. Around twice the hours per tire for less than half the cost per tire. Not many deals like that out there.
Alex Peterson
KADC, Wadena, MN
