Old 11-30-2008, 09:42 AM
TedTimmons TedTimmons is offline
Default Weight vs G limits
For my RV-6 the aerobatic weight is 1,375 lbs. I have calculated the equivalent G limit at other weights as follows and would like to know if my reasoning is correct.
Weight G's "G Weight"
1,375 6.0 8,250
1,450 5.7 8,250
1,500 5.5 8,250
1,550 5.3 8,250
1,600 5.2 8,250
My conclusion is that I can pull 5 G's at my max weight of 1,600 lbs and still be within the design specs.
Old 11-30-2008, 09:46 AM
Mel's Avatar
Mel Mel is offline
Default Yes
Your reasoning is correct. But I personally wouldn't push it to the limits. I stay within "utility category" limits (4.4Gs) at gross weight.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-30-2008, 11:01 AM
Geico266's Avatar
Geico266 Geico266 is offline
Welcome to VAF
Is it safe to assume the "weak points" in high "G's" are the spars & engine mounts? Where are the failure / damage points at?
Just curious.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 11-30-2008, 12:28 PM
Mel's Avatar
Mel Mel is offline
Originally Posted by Geico266 View Post
Welcome to VAF
Just curious.
Only the designer, and sometimes the test pilot know for sure!
Old 11-30-2008, 01:28 PM
szicree szicree is offline
The Van's -8 demonstrator got overstressed and snapped the wing around midspan. Remember though that our wings are of stressed-skin design, so I'm not sure that you can really say that the spar is the weakness.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 11-30-2008, 07:30 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Just remember that gross weight is not based solely on structural loading, and the CG envelope is not always a straight set of datum limits - the forward and aft points can change with Gross weight such that as you get heavier, the envelope gets smaller.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-30-2008, 09:45 PM
sjjonesnz sjjonesnz is offline
Given these are design/structural limitations, I assume they're not determined by our flight testing and so must be published somewhere. Can anyone point me to them as I'd like to put them in my PoH.
Cheers
Steve
Auckland, New Zealand
Flying RV-7QB/ZK-NVS/Aerosport 0320/Dual AF3500s/PMA8000B/GNS430W/SL30/GTX327/TT ADIP II
Old 12-01-2008, 05:44 AM
plehrke's Avatar
plehrke plehrke is offline
Default Loading Conditions
One other thing to keep in mind is that the aerobatic catagory and the utility catagory use different loadings to determine strength margins. In the utility catagory no analysis may be done for a unsymetric max g pull as that is not a manuver used by a utility category aircraft.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 12-01-2008, 06:42 AM
flion's Avatar
flion flion is offline
Page 15-21 in my RV-7 manual (old preview plans). Section 15 is Final Inspection and Flight Test. The relevant heading is G-Load Testing.
EAA Technical Counselor #5357
Old 12-01-2008, 01:28 PM
Thanks for that, but unless I'm missing something I can't see what the max. G-limit is at MAUW (1800lbs) and at weights between that and max aerobatic weight (1600lbs).
Knowing those limits I'll know how much fun I can safely have with my 220+lb friends
Cheers
Steve
