Old 11-29-2008, 10:02 AM
avi8tor50 avi8tor50 is offline
Default Wing tip riveting
Quick question. When riveting the HORIZONTAL rib in the wing tip are there any special precautions to apply when using the mushroom set of the rivet gun on the fiberglass? I am concerned about cracking the fiberglass when bucking the rivets for the rib.
Peter K
9A
Old 11-29-2008, 10:21 AM
scard's Avatar
scard scard is offline
Just go easy and don't drive it any more than necessary. It will be fine.
Scott Card
CMW E-Lift
Old 11-29-2008, 10:01 PM
GAHco's Avatar
GAHco GAHco is offline
Peter K
9A
Assuming none of this is concerning structure.
Do not use AD rivets, use "A" they are softer and better suited for this purpose.
I used nutplates and screws.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 11-30-2008, 05:56 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I assume you are referring to the small rib adjacent to the aileron. I set mine so the rib flanges were to the outside, facing the aileron, countersunk the rivet holes in the fiberglas tip, and used a squeezer with a 1" no hole yoke. A little filler made the rivets disappear.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 11-30-2008, 07:23 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Roberta
Yep... same here, worked out great!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-30-2008, 08:02 AM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
I assume you are referring to the small rib adjacent to the aileron....
He has a 9A, so he is probably referring to the additional metal rib spanning the tip. You can't use a squeezer on those rivets.
I used about 30 lbs of pressure on the rivet gun. You really have to be two people to do that. No cracks. I used regular rivets, but it does not look as nice as I had hoped. Will probably redo some of the rivets with soft rivets.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
