Keep VAF
Going
11-28-2008, 01:18 PM
Cowling Side Flanges
Fitting a cowl, no hinges, so a flange is needed along the side for 1/4 turn fasteners or screws/nutplates. The usual method is a riveted and bonded aluminum strip. The problem is that such a strip is flat, while the cowl is rounded, in particular as you near the front. I suspect this to be the cause of some misalignment reports after fastener installation. So, an alternate method for your amusement. I elected to lay up some glass flanges; quite easy to do.
Get the cowl fittted and trimmed to your satisfaction. Sand (40 grit) the inner surface of the lower cowl for good bonding. Paint two coats of PVA on the upper cowl inner surface. Jig the cowl (by whatever means necessary) so the outer surfaces of the two parts are flush and the parts can't shift fore and aft in relation to each other. I used scrap aluminum and clecos plus some shims and tape here and there. The cleco holes are a non-issue; plenty of surface filling in the future anyway.
The flange layup is 5 plies of tape, pre-impregnated in plastic and dropped in place whole over a light epoxy "surface prime" wipe. Stipple or roll to eliminate air bubbles.
When cured, pop it apart and trim/sand the new flange 1" wide.
The finished product precisely matches the upper cowl curvature.
After installing all the fasteners, I'll probably go back in and add more flange all across the front around the cooling inlets, just to eliminate any visual gap between the cowl sections.
BTW, with an angle valve 360 or 390 there is not much clearance down the left side (1/2" or so max). I may ditch the planned Skybolts here and use screws/nutplates instead.
Dan Horton
RV-8 SS
Barrett IO-390
11-28-2008, 01:59 PM
Super Moderator
Dan:
Looks good.
I suggest doing the same to the forward section by the air inlets to give the area some added strength and provide a spot for a screw/nutplate to secure this area tightly. I did this on my -8 cowling (see pics below). I used the conventional piano hinge method for the cowl but thought the forward area could use some extra strengthening/tightness due to its being literally at the pointy end of the stick and taking all the airflow abuse.
Fiberglass buildup before trimming.
And after trimming and adding a platenut. It seems to work well.
Chris
Chris Pratt (2021 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
11-28-2008, 02:43 PM
Hi Chris,
That's the flange I'm installing later, but I hadn't thought about a nutplate there. Hmmmm, thanks!
Dan Horton
RV-8 SS
Barrett IO-390
11-28-2008, 09:08 PM
Wish you guys had made these post about 9 months ago. Awesome work!
John Ratliff
N898R
RV-8
Saucier MS
04-30-2009, 07:09 PM
Dan, did you ever get around to installing the fasteners in those fiberglass flanges? If so, I'd be interested in seeing a photo. I'm sitting here looking at the piece of 2024-T3 I was going to use; after seeing your photos, I think I'm going to use glass instead- they look great. Thanks for posting this!
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
04-30-2009, 09:51 PM
Lars,
I used #8 nutplates. You know what they look like <g>
Dan Horton
RV-8 SS
Barrett IO-390
04-30-2009, 10:13 PM
Nice work
Hey Dan,
Nice work. Did you know Skybolt has some low profile fasteners? I got a couple of them for "close" places. I'm doing a 390 in the new project so step on all the land mines for me!!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
05-01-2009, 07:15 AM
Originally Posted by RV7Guy
Hey Dan,
Thank you, no I didn't know that, and no land mines yet. You doing an 8? The 390 has the same "problem" as the other angle valve installs; clearance to the cowl is very tight on the port side. The really tight spot isn't the split line, although fasteners need to be low profile there. It's up near the 1/4-20 screw ears on the heads, in particular at the most forward and rearward corners.
Dan Horton
RV-8 SS
Barrett IO-390
05-01-2009, 12:23 PM
Originally Posted by DanH
Lars,
All too well...
Mine will get Milspec fasteners, since I happen to have the kit on hand.
Lars Pedersen
Davis, CA
07-20-2009, 05:14 AM
fiberglas flange
Dan
How wide is the fiberglas tape you used to make up the cowl side flange?
Also when you preimpregnate the cloth tape, do you lay it up over wax paper on a flat surface and then just lay it upside down within the cowl and peel of the wax paper or lay each of the 5 tapes individually, stippling out the air bubbles as you go?
Oldgeezer
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
