Old 11-28-2008, 11:13 AM
pmccoy's Avatar
pmccoy pmccoy is offline
Default Wiring .206 Mic Plug
I am trying to make my own headset, based on an old thread I read here. I purchased a mic and plug form Aircraft Spruce
( http://www.vansairforce.com/communit...highlight=.206 )
Noise-Canceling Microphone. Fits all C40 Model Headsets (David Clark, Softcomm, Telex, etc.) Part No. 11-04838 $19.85
.206" COMMERCIAL MIC PLUG - (S-267) (PJ-068) Mates with JJ-033, S-12B, CES830. Black plastic handle with .206" dia. chrome plug. 3 conductors. solder plug and cable clamp. P/N 11-00702 $6.50
I will also use a set of NR-10 Comply Comfort earplugs.
My problem comes in the wiring on the mic to the plug. The mic has two wires. My first try was to put one wire to the 'Tip', the second wire to the 'Ring' and solder the shield to the 'Ground'. This didn't work.
Anyone have another idea on how to wire the mic to .206 plug???
Ideas would be appreciated.
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
Old 11-28-2008, 11:33 AM
rvbuilder2002's Avatar
The wire connections on a mic plug are as follows...
Mic ground goes to the sleeve (long portion)
Mic + goes to the ring
The tip is used for transmit key to activate transmit on the radio
(not used in your application)
Scott McDaniels
Hubbard, Oregon
Old 11-28-2008, 12:33 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Aeroelectric Bob....again....
...has nice pictures to go along with a description....
Article here....
http://www.aeroelectric.com/articles...k/micjack.html
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Last edited by az_gila : 11-28-2008 at 12:35 PM. Reason: changed pic from jack to plug
Old 11-28-2008, 12:54 PM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Smile
Peter,
I had the same problem last month, I did the wire for my flying helmet and found this document very usefull.
Hope helps
http://www.rv8.it/support/david%20clark%20wiring.pdf
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
Old 11-28-2008, 01:19 PM
pmccoy's Avatar
Thanks for the info. I will wire that up and give it a try.
_____________
Peter McCoy
www.myrv9.com
