Old 11-28-2008, 10:30 AM
Michael Burbidge Michael Burbidge is offline
Default Close quarters pop riveting
I have to pop rivet the attach angles to the tank baffle. I find that my pull riveter will not clear the body of the attach angle so that I can put in the temporary pop rivets. I have read that some have ground the nose of their pull riveter some to get into close quarters. I'm wondering if I can do this with mine without ruining it. It is hard to tell from looking how much I can grind down the nose.
My pull riveter is from Cleveland and is PowerLink 30. Has anyone ground the nose down on this model?
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 11-28-2008, 10:43 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Michael-
I wouldn't do this with an expensive pop-riveter. Just go down to Harbor Freight and get a cheap one for $3.00 to grind down if you find it to be necessary. My Harbor Freight puller (the only one I have) is going strong and the riveting is virtually complete.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Mel's Avatar
Mel Mel is offline
Go down to the hardware store and buy the cheapest "folded metal" pop rivet puller you can find. These will get you into very tight corners.
On my bi-plane, I had to pull lots of rivets that were at the bottom of a 5/8" channel. This was the only thing I found that would work.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-29-2008, 05:03 AM
skyyking56 skyyking56 is offline
Default Master mechanic pop riveter from Ace Hardware
Michael,
I agree with Mel...I was pondering this also and went thru my old toolbox and found a Master Mechaic brand from Ace harware or True Value.... folded metal pop riveter that I have had for probably 30 years and I didnt have to grind it at all...It just barely fit against the angle but did work just fine..It is now on my peg board of tools. I bet anything that you can still purchase the same one at a local hardware store and it will probably be about $10.
Good luck.
Jim
7A Wings (Still)...I think I'm the slowest wing builder in history
Old 11-29-2008, 05:39 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Check this thread - lots of ways to skin the cat - and the beauty of the VAF
http://www.vansairforce.com/communit...ad.php?t=35534
Old 11-29-2008, 05:44 AM
Alschief Alschief is offline
Default Riveting in Tight Places
Try this link at EAA, it shows several Videos.
One is for riveting in tight places.
It has a video on Pop Riveting Tools and Modifications.
http://www.eaa.org/video/homebuilders.html[/url]
AL & Brenda Smith
RV12, UL Power N495BA Flying
RV6 N495AB Sold
KEOS Neosho, MO
alsmith@olemac.net
alsmith@ulpower.com
Old 11-29-2008, 07:48 AM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Originally Posted by Mel View Post
Go down to the hardware store and buy the cheapest "folded metal" pop rivet puller you can find....
Agreed. Mine was an Arrow brand that I bought at Home Depot a while back (have not seen it there lately though).
Here's a photo of it.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
