Originally Posted by Scott Chastain
You need to install the Anti Rotation Bracket, part T-715. They are pre-fabbed now and easy to install. Good luck!
Scott, aren't those for the regular pick-up tubes ?
We are talking flop tube here.
Steve, If you've already pro-sealed it, thats fine, just add the angles like in my photo and that should prevent the elbow from rotating.
The proseal helps, but I felt the angles would be better support in the long run.
