Originally Posted by Bubblehead
Does anyone know a source for roller rocker arms for a 180 hp IO-360? I am installing new ECI cylinders and a couple of the old rockers are not serviceable. Rather than buy old technology, if the price is reasonable I'd like to upgrade to roller rockers.
John
At one point in the past, they were available.
I have this info:
KEN HATFIELD ENTERPRISES
1260 N.W. Perimeter Road
Troutdale Airport, OR 97060
(503) 666-5814
FAX: (503) 666-6332
I do not know if they still offer them. If you find out, please report back with price.
Here is a paste from the flyer that I have.
Manufactured from 7075T6 aluminum with two needle bearings for the rocker shaft and hardened steel cup for the pushrod socket. The valve roller is 1/2" in diameter and rolls on a 1/4" hardened steel axle.
The roller rocker dramatically reduces side load on valves and thus reduces and/or eliminates the rapid and excessive valve guide wear experienced by Lycoming engines which is evidenced by Lycoming 5.B.#388B recommending inspection every 400 hours.
One of the four required inspection~ could cost as much as a set of roller rockers without considering the cost if excessive valve guide wear results in a premature top overhaul.
How many valves have taken the blame for failure when the real culprit was an excessively worn guide.
The original friction rockers vary as much as .043 in total valve opening where as all our roller rockers open the valves the maximum opening allowed.
This will obviously produce a smoother running and more efficient engine.
They are interchangeable with the original friction rockers and do not require any modification or parts changes.
The rockers incorporate an oil passage which lubricates the rocker arm needle bearing and the exhaust has a passage which supplies oil to the exhaust valve stem.
The roller rocker arm used in the angle valve cylinder incorporates a needle thrust bearing instead of a friction thrust washer.
The flyer that I have is in PDF format. I sent it by email to the email address that you have listed on VAF.
