Old 11-26-2008, 09:17 PM
N200PF's Avatar
N200PF N200PF is offline
Default LED Strobes - Back to the drawing board...
Well I heard back from Bill at CreativeAir today that he is not going to be able to knock down the RF issues he's ben having with the LED strobes. I purchased a set several weeks ago (never took delivery) and he was GREAT about keeping me in the loop on his progress towards fixing the issue. However, in the end, the LED strobes require a complete redesign to "meet his standards" of reduced noise.
I would really like to do LED strobes rather than the old stand-by Whelen's for many reasons. I've contacted AeroLED...any others I should be looking at? I thought there would be more choices by now.
Thanks! - Peter
Peter Fruehling
St. Paul, Minnesota - Based at ANE
RV-4 - Sold
RV-7 - Sold
RV-10 - Partners in N829EC
2019 Dues Paid - Have you paid yours?
Old 11-26-2008, 10:18 PM
craigvince's Avatar
craigvince craigvince is offline
Try Kuntzelman Electronics.
Old 11-26-2008, 10:32 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default AVEO Engineering . . . . .
. . . . . is who you should check out http://www.aveoaviationlights.com/. They already have their AveoFlash series with a LED Nav/Position/Strobe unit for unenclosed wigtips. The AveoFlashEW for enclosed wingtips (like our RVs) is due in December as well as a landing and taxi light to fit in the wingtip (all LED). They also make the PosiStrobe for the tail to provide the rear position and strobe where you would normally use a Whelen 500.
These lights are 100% LED and (at least according to AVEO) are compliant with the FAA requirements and are absolutely quiet electrically.
I have a Posistrobe coming from the distributor that is on UPS right now and is due for delivery on 12/1 (these have been on backorder from Spruce since at least August). As soon as I get it, I'll post some photos and some "pireps" on it.
In the mean time, here's some photos of the PosiStrobe the Aveo folks sent me.
BTW. I am not affiliated in any way with Aveo Engineering - just a customer who really hopes to be able to go 100% LED!
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 11-26-2008, 10:50 PM
DickDe DickDe is offline
Default Strobes
Yes...look at www.strobesnmore.com. They have regular strobes and LED flashers from Whelen, Nova, and others for emergency vehicles but I have seen them on experimentals.
Dick DeCramer
RV6 N500DD flying w/Aeroflash strobes
RV8 fuselage...will Build my own lighting
Northfield, MN
Old 11-27-2008, 05:30 AM
rleffler's Avatar
rleffler rleffler is offline
It is the Nova strobes that CreativAir was reselling. When these LEDs strobe, they produce a considerable amount of RF.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-27-2008, 04:30 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default aveoflash
A little bird told me that a pretty cool new light package from aveo will be making it to our favourite kits plane company's inventory in DEC.
We will see, ordering that from vans at a good price would be a really sweet upgrade from the old standard choices.
We will see.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 11-27-2008, 10:22 PM
N200PF's Avatar
Great Info Guys!!!
Thanks for pointing me in the right direction! I was pretty bummed after hearing back from Bill on his solution. We'll see what we have in December!
- Peter
Peter Fruehling
RV-4 - Sold
RV-7 - Sold
Old 12-01-2008, 01:39 PM
N200PF's Avatar
Dan did you get your PosiSTROBE? I'm intersted to konw what you think and if it's as quiet as they're claiming!
Also, I can't tell from their web site if the AveoFlashEW is just a strobe or contains position lights as well. All I need for the tips are the strobes. I have another LED solution for the position lights.
- Peter
Peter Fruehling
RV-4 - Sold
RV-7 - Sold
Old 12-01-2008, 02:06 PM
Default The PosiStrobe is IN ! ! !
- Peter
I just got it this morning on UPS. I have been playing with it some and will post a more complete pirep later.
My initial testing using my Icom A210 radio with a Comant CI-122 antenna is that there is no interference! I have the radio sitting on the bench and the antenna attached to a 2' X 2' piece of aluminum for a ground plane. I can receive KHSV approach, tower, and ATIS with this set up. With the PosiStrobe hooked to the same power supply as the radio, there was no difference in reception at all - even receiving some weaker signals from aircraft talking to approach/tower. A couple of times, if I actually laid the PosiStrobe on the radio or held the antenna right next to it, I think I might have heard a little background noise but it doesn't seem to be very repeatable.
A couple of quick observations -
- The PosiStrobe does 48 double flashes/minute.
- The position light appears to be on if you have the strobe on.
- After running the unit for a couple of hours, it is only warm to the touch - not hot (edit: after 3 hours, IR thermometer says 109 degrees F).
More later . . . . .
The AveoFlashEW is both position and strobe.
Dan Langhout
Old 12-01-2008, 10:52 PM
N200PF's Avatar
GREAT NEWS!!!
Did you work with anyone specific over there Dan? I'll be anxious to learn more about the AveoFlashEW and if they built it as a stand alone wing strobe...not to include red or green position lights.
That's what I need to go with the PosiStrobe.
- Peter
Peter Fruehling
RV-4 - Sold
RV-7 - Sold
